ElaQCW (QCW - DRSSTC) By Marek1CZE
Добавлено: 27 сен 2021, 13:05
Hello and good day,
I'm new here so I'd like to introduce myself as a young electronics engineer dealing mainly with high voltage and I'd like to present Tesla coils like DRSSTC, QCWDRSSTC and VTTC.
As it is written in the header of the post, I am currently working on my second QCW DRSSTC for which I am inventing the fourth version of the modulator for the Buck and DR elector control.
In the latest version, I already have all the electronics handled via fiber optics or possibly Wi-Fi. (It is mainly just the starting pulse for the modulator).
In this version I still have voltage control for the power part via variac.
And actually I have questions around the whole project. With the previous QCW I had a number of problems to get through and it cost me a lot of IGBTs...
With the previous versions I didn't address the UVLO of the DR end stage and the Current limiting of the primary circuit, I also never could estimate the upper peak of the primary circuit. I would need an explanation on how to calculate just this peak correctly. Also the most important problem was the Buck, I couldn't properly calculate the inductance of the LowPassFilter so I did it by estimation and loaded it with a 2R 1000W resistor to simulate the bridge load and primary circuit.
Therefore, I would need an explanation on how to properly calculate this filter and what to have the gap in inductance.
My first QCWDRSSTC has a primary current of about 95Apeak at 325v, the secondary coil is only 150mm*75mm and is wound 0.24mm. The resonant capacitor is 7nF 15Kv and the discharge length is about 150cm. There is a dual bridge of the no longer obtainable IRGP50b60pd1 and I have an SKM200GAL1200 in the Buck.
I would be grateful for any help and will post photos of the build of my second QCW DRSSTC - ElaQCW (Elishka).
Regards Marek1CZE, MEOW.
New QCW driver ElaQCW-V.4
My QCW is left. 120cm spark.
Again my old QCW. 150cm spark.
