TFT display vs IPS display: What are the Differences, Features, Pros and Cons?
aisen
Сообщение aisen » 28 мар 2022, 15:55
Before you get a new monition for your organization, comparing the TFT display vs IPS display is something that you should do. You would want to buy the monitor which is the most advanced in technology. Therefore, understanding which technology is good for your organization is a must. click to view 7 Best Types Of Display Screens Technology.
Technology is changing and becoming advanced day by day. Therefore, when you are looking to get a new monitor for your organization, LCD advantages, and disadvantage, you have to be aware of the pros and cons of that monitor. Moreover, you need to understand the type of monitor you are looking to buy.
Now, understanding the technology from the perspective of a tech-savvy person may not be the ideal thing to do unless you are that tech-savvy person. If you struggle to understand technology, then understanding it in a layman’s language would be the ideal thing to do.
That is why it is important to break it down and discuss point by point so that you can understand it in a layman’s language devoid of any technical jargon. Therefore, in this very article, let’s discuss what exactly TFT LCDs and IPS LCDs are, and what are their differences? You will also find out about their pros and cons for your organization.
Understanding TFT LCD
The word TFT means Thin-Film-Translator. Click to view: what is TFT LCD, It is the technology that is used in LCD or Liquid Crystal Display. Here you should know that this type of LCDs is also categorically referred to as active-matrix LCDs. It tells that these LCDs can hold back some pixels while using other pixels. So, the LCD will be using a very minimum amount of energy to function. TFT LCDs have capacitors and transistors. These are the two elements that play a key part in ensuring that the display monitor functions by using a very small amount of energy without running out of operation.
Now, it is time to take a look at its features that are tailored to improve the experience of the monitor users significantly. Here are some of the features of the TFT monitor;
TFT LCD products are diversified, convenient and flexible, easy to maintain, update, upgrade, long service life, and many other characteristics
The display range covers the application range of all displays from 1 inch to 40 inches as well as the large projection plane and is a full-size display terminal.
(1) High-Resolution Display
Display quality from the simplest monochrome character graphics to high resolution, high color fidelity, high brightness, high contrast, the high response speed of a variety of specifications of the video display models.
(2) The Raw Materials Of The Display Screen Have Good Environmental Protection
No radiation, no scintillation, no harm to the user’s health. In particular, the emergence of TFT LCD electronic books and periodicals will bring humans into the era of paperless office and paperless printing, triggering a revolution in the civilized way of human learning, dissemination, and recording.
(3) Wide Application Range
It can be normally used in the temperature range from -20℃ to +50℃, and the temperature-hardened TFT LCD can operate at low temperatures up to -80 ℃. It can not only be used as a mobile terminal display, desktop terminal display but also can be used as a large screen projection TV, which is a full-size video display terminal with excellent performance.
(4) Mature Manufacturing Technology
The manufacturing technology has a high degree of automation and good characteristics of large-scale industrial production. TFT LCD industry technology mature, the mass production rate of more than 90%.
(5)TFT LCD Is Easy To Be Integrated And Updated
It is a perfect combination of large-scale semiconductor integrated circuit technology and light source technology and has great potential for further development.
(6) Good Display Screen Effect
TFT LCD screen from the beginning of the use of flat glass plate, its display effect is flat right angles, let a person have a refreshing feeling. And LCDs are easier to achieve high resolution on small screens.
Understanding IPS Displays
The word IPS refers to In-Plane-Switching which is a technology used to improve the viewing experience of the usual TFT displays. You can say that the IPS display is a more advanced version of the traditional TFT LCD module. However, the features of IPS displays are much more advanced and their applications are very much widespread. You should also know that the basic structure of the IPS LCD is the same as TFT LCD if you compare TFT LCD vs IPS.
So, What Are The Features Of IPS Displays?
Here are some of the notable ones that you should know.
ips
1)Quick And More Stable Response Time
As you already know, TFT displays do have a very quick response time which is a plus point for it. But, that does not mean IPS displays a lack of response time. In fact, the response time of an IPS LCD is much more consistent, stable, and quick than the TFT display that everyone used to use in the past. However, you will not be able to gauge the difference apparently by watching TFT and IPS displays separately. But, once you watch the screen side-by-side, the difference will become quite clear to you.
2)Viewing Angle Is Much Wider
The main drawback of the TFT displays as figured above is the narrow-angle viewing experience. The monitor you buy for your organization should give you an experience of wide-angle viewing. It is very much true if you have to use the screen by staying in motion.
So, as IPS displays are an improved version of TFT displays the viewing angle of IPS LCDs is very much wide. It is a plus point in favor of IPS LCDs when you compare TFT vs IPS. With a TFT screen, you cannot watch an image from various angles without encountering halo effects, blurriness, or grayscale that will cause problems for your viewing.
It is one of the major and remarkable differences between IPS and TFT displays. So, if you don’t want to comprise on the viewing angles and want to have the best experience of viewing the screen from wide angles, the IPS display is what you want. The main reason for such a versatile and wonderful viewing angle of IPS display is the screen configuration which is widely set.
3)Greater Transmittance Of Frequencies
Now, when you want to achieve wide-angle viewing with your display screen, you need to make sure it has a faster level of frequency transmittance. It is where IPS displays overtake TFT displays easily in the comparison because the IPS displays have a much faster and speedier transmittance of frequencies than the TFT displays.
Now the transmittance difference between TFT displays and IPS displays would be around 1ms vs. 25ms. Now, you might think that the difference in milliseconds should not create much of a difference as far as the viewing experience is concerned. Yes, this difference cannot be gauged with a naked eye and you will find it difficult to decipher the difference.
However, when you view and an IPS display from a side-by-side angle and a TFT display from a similar angle, the difference will be quite evident in front of you. That is why those who want to avoid lagging in the screen during information sharing at a high speed; generally go for IPS displays. So, if you are someone who is looking to perform advanced applications on the monitor and want to have a wider viewing angle, then an IPS display is the perfect choice for you.
4)Better Representation And Reproduction Of Colour
As you know, the basic structure of the IPS display and TFT displays are the same. So, it is quite obvious that an IPS display would use the same basic colors to create various shades with the pixels. However, there is a big difference with the way a TFT display would produce the colors and shade to an IPS display.
The major difference is in the way pixels get placed and the way they operate with electrodes. If you take the perspective of the TFT display, its pixels function perpendicularly once the pixels get activated with the help of the electrodes. It does help in creating sharp images.
But the images that IPS displays create are much more pristine and original than that of the TFT screen. IPS displays do this by making the pixels function in a parallel way. Because of such placing, the pixels can reflect light in a better way, and because of that, you get a better image within the display.
As the display screen made with IPS technology is mostly wide-set, it ensures that the aspect ratio of the screen would be wider. This ensures better visibility and a more realistic viewing experience with a stable effect.
Difference Between TFT Displays And IPS Displays
As you already know the features of both TFT and IPS displays, it would be easier for you to understand the difference between the two screen-types. Now, let’s divide the matters into three sections and try to understand the basic differences so that you understand the two technologies in a compressive way. So, here are the difference between an IPS display and a TFT display;
• Clarity Of Colour
Now, before starting the comparison, it is quite fair to say that both IPS and TFT displays have a wonderful and clear color display. You just cannot say that any of these two displays lag significantly when it comes to color clarity.
However, when it comes to choosing the better display on the parameter of clarity of color, then it has to be the IPS display. The reason why IPS displays tend to have better clarity of color than TFT displays is a better crystal oriental arrangement which is an important part.
That is why when you compare the IPS LCD with TFT LCD for the clarity of color, IPS LCD will get the nod because of the better and advanced technology and structure.
• Angular Screen View
IPS displays have a wider aspect ratio because of the wide-set configuration. That is why it will give you a better wide-angle view when it comes to comparison between IPS and TFT displays. After a certain angle, with a TFT display, the colors will start to get a bit distorted.
But, this distortion of color is very much limited in an IPS display and you may see it very seldom after a much wider angle than the TFT displays. That is why for wide-angle viewing, TFT displays will be more preferable.
• Energy Consumption
When you are comparing TFT LCD vs. IPS, energy consumption also becomes an important part of that comparison. Now, IPS technology is a much advanced technology than TFT technology. So, it is quite obvious that IPS takes a bit more energy to function than TFT.
Also, when you are using an IPS monitor, the screen will be much larger. So, as there is a need for much more energy for the IPS display to function, the battery of the device will drain faster. Furthermore, IPS panels cost way more than TFT display panels.
TFT Displays: Pros And Cons
Pros
1. The best thing about TFT technology is it uses much less energy to function when it is used from a bigger screen. It ensures that the cost of electricity is reduced which is a wonderful plus point.
2. When it comes to visibility, the TFT technology enhances your experience wonderfully. It creates sharp images that will have no problems for older and tired eyes.
3. The screens that are made with TFT technology have a very attractive physical design and appearance.
Cons
1. One of the major problems of TFT technology is that it fails to create a wider angle of view. As a result, after a certain angle, the images in a TFT screen will distort marring the overall experience of the user.
2. When the TFT screen is used for printing images, the technology fails to show the exact colors as it is there in the actual images.
IPS Displays: Pros And Cons
Pros
1. Screens made with IPS technology can easily be installed in the walls as it is low in depth.
2. The devices that have screens made with IPS technology may have longer battery life.
3. The colors produced by an IPS display are very much clear, pristine, and dynamic.
4. The biggest plus point of IPS displays is its wide viewing angle that ensures stable and clear images and results in a great viewing experience.
Cons
1. IPS displays have a huge cost and it is one of the major drawbacks of the LCD.
2. Another notable problem of the IPS LCD is the problem with brightness as many think that it may not be ideal to use it in darker places.
TFT Display Vs IPS Display Which Is Better
Although IPS screen technology is very good, it is still a technology based on TFT, the essence of the TFT screen. Whatever the strength of the IPS, it is a TFT-based derivative.
The Bottom Line (TFT Vs IPS )
Finally, as you now have a proper understanding of the TFT displays vs IPS displays, it is now easier for you when it comes to choosing one for your organization. Technology is advancing at a rapid pace. You should not be surprised if you see more advanced display screens in the near future. However, so far, TFT vs IPS are the two technologies that are marching ahead when it comes to making display screens.
STONE provides a full range of 3.5 inches to 15.1 inches of small and medium-size standard quasi TFT LCD module, LCD display, TFT display module, display industry, industrial LCD screen, under the sunlight visually highlight TFT LCD display, industrial custom TFT screen, TFT LCD screen-wide temperature, industrial TFT LCD screen, touch screen industry. The LCD module is very suitable for industrial control equipment, medical instruments, POS system, electronic consumer products, vehicles, and other products.
STONE Tech is an LCD manufacturer located in Beijing, China. It was founded back in 2010, and it has been developing TFT LCD display modules ever since. These modules can be used for a variety of different machines including electric equipment, precision instruments, and civil electronics etcetera.
One of the main benefits that you get with Stoneitech.com is that there is a wide range of diverse products that you can purchase. For example, there are three different application types that you can choose from which include the Industrial Type, Advanced Type, and Civil Type. Similarly, there is a range of different sizes that you can choose from. There are 11 different sizes that you can buy, ranging from the smallest 3.5-inch display to the large 15.1-inch one. The same goes for the Android series which where you can choose between 4.5-inch and 31.5-inch displays.
aisen
Сообщение aisen » 29 мар 2022, 16:12
The full name of TFT is thin film transistor. Generally, most liquid crystal displays are called "active panel", and the core technology of "active panel" is thin film transistor, that is, TFT, which leads to the change of people's name for active panel into TFT. Although this name is not appropriate, it has been so for a long time.
A simple example is like talking about the "universe" and people think of "Korea". Although it is not appropriate, it is OK to understand it.
The working mode of TFT is that each liquid crystal pixel on the liquid crystal display is driven by a thin-film transistor integrated behind it, that is, TFT. In short, TFT is to configure a semiconductor switching device for each pixel, which can directly control each pixel through point pulse. Moreover, because each node is relatively independent, it can also be controlled continuously.
The full name of IPS screen is in plane switching. IPS technology changes the arrangement of liquid crystal molecular particles, adopts horizontal conversion technology, speeds up the deflection speed of liquid crystal molecules, ensures the picture clarity and strong expressiveness when shaking, and eliminates the blurring and water ripple diffusion phenomenon of traditional liquid crystal display when receiving external pressure and shaking.
Due to the rotation of liquid crystal molecules in the plane, IPS screen naturally has a very good visual angle performance, and the four axial angles can be close to 180 degrees.
Although IPS screen technology is very powerful, it is still a technology based on TFT, and its essence is TFT screen. No matter how strong IPS is, you have to shout "Daddy" safely when you see TFT. After all, it is derived from TFT.
